Arriva State of The Fleet
RE: Arriva State of The Fleet
(15 Sep 2026, 9:02 pm)Mike_98 wrote I mean, if Stockton would allocate them correctly, The Lites are perfect for the Town services but looking at Arriva's operations down south, it looks so bad. Hearts & Essex are still operating a Nimbus. Kent & Surrey still have old Solos and a old E200. Also they got some Gemini 1's. Beds & Bucks still have a fair few Olympus's. Unsure what Arriva's plans are down there for the future but yeh. There are more depots with a tonne of older vehicles which need replacing then Stockton. They should just cash in on the Streetlites as soon as they can possibly do so for them as I can't really see in the future any smaller company wanting to buy a battered up Arriva Streetlite compared to a Pulsar.
Wouldn't mind the E200MMC's coming to Stockton though as they would be useful for ALL of the services. Evoras would be alright too. Unsure how the allocating procedure actually works but I would have Streetlites on the services:
X2
17A
17B
29A
If it were necessary, I would have them on the X66/X67/63/64/65. Maybe also on Short X12's. I'm not familiar on the X12 or the X22 services on how hilly they are.
Aye you're right on the Streetlite's to be fair, I know it's all speculation but truthfully I wouldn't be surprised more if the Streetlite's end up in Northumbria.
I can't say I particularly like the things but they're ideal for the 1/2/35/57/57A/553 really and there's already 8 of the batch here anyway, might aswell replace the rest rather than having a mixed fleet. There isn't really any need for any powerful single deckers up here as they're not really needed as the expresses shouldn't have them on. Should release a few of better Pulsar's for the 28/28A/29/X22 and the likes which let's be honest have always been a dumping ground tbh.
It's the Evora's, especially the backend of the Redcar batch (6 of them) that I wouldn't be surprised you's get. Be ideal for the X2/X3/X4 and have the whole lot Evora operated, beyond who knows I'm sure we could come up with all sorts of ideas.
(14 Sep 2026, 4:46 pm)Storx wrote Not surprised, all this investment has done nothing at all to sort out the issues at Ashington. After going round the circles, basically the end result is 6x B9TL's which are not reliable seemingly replacing 6x Pulsar's which are reliable and absolutely nothing else.
Arguably the depot is in a worse position.
Mind it seems like they've dragged 7403 out now to sort that board but 7554 has decided it's had enough (again) on the 57 instead and now the X22 is missing a board ironically which is the 6pm out of Newcastle  Shy
The 14/64/15-plate E400s are in a shocking state, and if we're honest have been neglected since about 2021. Obviously the common theme here is that they (mostly) have been based out of Ashington depot, whereas the DB300s (replying to later posts in this too) have all been Blyth based.
The only 2 E400s which seem dependable are 7524/5, which were decent at Ashington and have been at Blyth since Jesmond closed. The entire 64-plate batch have been ruined, 7553 is barely able to do anything beyond a 1 (got used as a replacement on an X18 today which went as expected), and 7554 is barely able to leave the depot.
I'd counter that the Pulsars are reliable now, they have gone through horrific spells at Ashington too. Again though, the question there is whether that is due to engineering or age of the buses.
The B9s are fine at Ashington if used on the 35 as they should be. The issue, as you point out, is that the bean counters have taken away the rest of the decent stock so you've only got 19 buses for 23 X18/20 duties. They've then got, as far as I can tell, 23 saloons for 12 booked saloon duties. So some of those will always end up on decker work, but actually in reality even more will because of how bad those E400s are and so they're instead being used on the 1/57. Truly awful fleet planning, and whoever allowed the 17/72-plates to leave the region without suitable replacement needs put on a PIP.
(15 Sep 2026, 8:17 pm)Storx wrote tbf, the DB300's are still a rock up here aswell if you ask me, absolute workhorses considering they're all out 7 days a week from 5am - 12am which ironically can't be said about the new electrics which are in bed by 7pm every night - does anyone actually know the reason for this?
It's wild speculation this, but I have a feeling you's might benefit from some of the Merseyside cascades. Unless something changes and Merseytravel start buying the old fleets then everything is leaving.
There's 50x E200MMC's and 24x Evora's to go somewhere (plus 19 DF Streetlite's, including the ex X4 ones, but you probably don't want them). Obviously there's all the other divisions fighting for stuff aswell as there's a lot of ancient single deckers around.
Worth noting that the existing E200MMC's allocated on Merseyside are earmarked for Runcorn and the newer Evora's are all due to go to Wales.
(15 Sep 2026, 10:19 pm)peter wrote Worth noting that the existing E200MMC's allocated on Merseyside are earmarked for Runcorn and the newer Evora's are all due to go to Wales.
And I'd be very surprised if anything from the Merseyside fleet ends up making its way up here. More likely to end up with some of the Yorkshire vehicles when Dewsbury and Heckmondwike go Weaver in the spring - plenty of E400MMCs being freed up from Heckmondwike.
(16 Sep 2026, 6:58 pm)Ryland wrote According to bus times 3051 is now withdrawn as repairs are deemed too expensive
Yeah 3053 should be on its way to replace it but it was currently VOR at Darlington, believe it came back into service yesterday or today, so will probably move up this weekend, when ashington come and borrow a bus
(15 Sep 2026, 9:56 pm)PH - BQA wrote The 14/64/15-plate E400s are in a shocking state, and if we're honest have been neglected since about 2021. Obviously the common theme here is that they (mostly) have been based out of Ashington depot, whereas the DB300s (replying to later posts in this too) have all been Blyth based.
Aye, to be fair have to question whether it is Ashington or it's the buses mind I noticed Blyth got dumped with 7527 and 7530 the other week and both died so who knows. They really are awful though. Not sure if it's a blip but 7403 has been a bit of an issue so far aswell. Seems to have had issues again today which means there's dropped boards on the 57/57A (again).
I know some probably say I'm critical but the 57/57A which is the route I use sometimes has been diabolical for years, bar the period when it had the brand new E200MMC's but they were took away like everything else and it's just been a s**tstorm ever since whether it's been Solos (they really were awful), Pulsars, E400's or now B9's being a joke on it. Gateshead Taxis get slated on here but the 19, in comparison, is the polar opposite in terms of reliability to the stage I've noticed half of Seghill just use it now for Cramlington (and I don't blame them really).
(16 Sep 2026, 11:11 am)Kuyoyo wrote And I'd be very surprised if anything from the Merseyside fleet ends up making its way up here. More likely to end up with some of the Yorkshire vehicles when Dewsbury and Heckmondwike go Weaver in the spring - plenty of E400MMCs being freed up from Heckmondwike.
Ah didn't realise Heckmondwike was part of the Dewsbury tendering (knew that was gone). Learnt something new today tbf.
(1 hour ago)TransitObserver wrote Looks like Streetlites 1574 and 1581 are at Blyth any idea why and for how long?
7622, 7631, and 7633 are all at Ashington stinking up the 1/2/35/57 because they aren't compliant with the CAZ. Obviously, again, this is a net negative for both depots as the Newcastle routes get stuck with inadequate stock.
Speaking of which, just checked the allocations of the X21/22 today. Out of the 12 duties, 7 are saloon operated. Not exactly an appealing prospect for punters given 3 of those are 15 years old and have never seen a re-trim. I'd imagine there'll be more saloons on shortly too, as 7401/3 and 7527 have been allocated to the X21 and those three aren't exactly reliable.
Is today's problem that operators are expecting the same output and utilisation of more modern and complicated vehicles, as what they did with Leyland and Volvo Olympians which were a piece of p*** mechanically?
GNE back in the golden era purchased 1 spare vehicle for every 7-8 new ones purchased. Arguably a bit overkill, but things were reliable and GNE could do more 'preventative' maintenance rather than reactive.
For Arriva's Northumberland Network especially Ashington & Alnwick outstations, there should be 1x spare vehicle purchased for every 7-8x new vehicles purchased.
(38 minutes ago)L469 YVK wrote Is today's problem that operators are expecting the same output and utilisation of more modern and complicated vehicles, as what they did with Leyland and Volvo Olympians which were a piece of p*** mechanically?
The oldest decker Ashington have (excluding the sheds they have on loan from Blyth) is 12 years old. There's absolutely no reason they should be unreliable as they are, the reason for the unreliability is poor maintenance and incompetent fleet planning.
Plenty of other companies use older vehicles (E400s, in many cases) on far more intense work than the X21/22, yet things like 7530 and 7554 can't even complete a day on there.
Put it this way, 7514-7 were widely considered to be dogs by the end of their time at Ashington. They were 13 years old and still, just about, putting in 6 days a week on Alnwick services by the time the 72-plate batch of MMCs replaced them. Compare them to how 7526-33 and 7553/4 are now, there has clearly been a significant reduction in competence at that depot over recent years. 7526-33 and 7553/4 have been shocking for about 3 years now, some of them with significant spells of not even being in service let alone sent to Alnwick/Berwick every day, and are all still younger than the 09-plates were when they left.
