QuayCity VOLTRA Yutong E12's
Martijn has revealed the new Yutong E12's for the ??? Look much nicer than the Voltra 1's Interior Wise https://twitter.com/MartijnGNE/status/15...0781570048
(08 Jul 2022, 1:02 pm)KingSlayerRBLX wrote Martijn has revealed the new Yutong E12's for the ??? Look much nicer than the Voltra 1's Interior Wise https://twitter.com/MartijnGNE/status/15...0781570048Nice yellow front end
(08 Jul 2022, 1:02 pm)KingSlayerRBLX wrote Martijn has revealed the new Yutong E12's for the ??? Look much nicer than the Voltra 1's Interior Wise https://twitter.com/MartijnGNE/status/15...0781570048I hate the Voltra's so much, where the wheelchair space is cos they now have NSA Screens it just blocks the view. I hate them, not to mention the NSA never seem to work
(08 Jul 2022, 3:53 pm)Unber43 wrote the awful display for next stops etc, where the wheelchairs go, it blocks the entire view down the bus.Does it really though, that ~20cm tall screen blocks the 'entire view' down the bus?
(08 Jul 2022, 4:08 pm)streetdeckfan wrote Does it really though, that ~20cm tall screen blocks the 'entire view' down the bus?
That screen is there so people in wheelchairs can see the next stop info, you're suggesting they take away an accessibility feature so you can see a little bit more of the windscreen?
Get a grip
Sent from my AC2003 using Tapatalk
(08 Jul 2022, 4:43 pm)F114TML wrote Yeah, could it not go there?Then you're directly blocking the view of the front seats, which id argue is worse.
Tbh though, it's only really going to block your view to the front if you're sitting in one of the seats right at the back.
I'm also not a massive fan of the green on the seats and the grassy floor, could they not have gone for a darker shade?
(08 Jul 2022, 4:49 pm)streetdeckfan wrote Then you're directly blocking the view of the front seats, which id argue is worse.Not really unless I'm completely misjudging the size of the seats. If you're so short you can't see out the side window, frankly, you're not going to have much of a view anyway.
When you're at the back, it's not blocking your view at all, maybe I'm just weird, but I'm basically never looking directly forward out of the front window that's like 6-7m away. When you're that high up, your view our of the window is going to be mostly road with a hint of pavement. And, if you're lucky, a bit of reg plate of the car in front
(08 Jul 2022, 4:50 pm)F114TML wrote Not really unless I'm completely misjudging the size of the seats. If you're so short you can't see out the side window, frankly, you're not going to have much of a view anyway.Isn't the window line on the Yutongs quite high? I haven't been on one for a while so I can't quite remember.
(08 Jul 2022, 4:55 pm)streetdeckfan wrote Isn't the window line on the Yutongs quite high? I haven't been on one for a while so I can't quite remember.if you look at some of the seats, in the photo before the steps, that window line is so high, its taller than the seats.
If they're the same height as the V3s, then the top of the head rest is about the height of my chin, so it probably wouldn't affect me in terms of view, but it would feel more enclosed.
(08 Jul 2022, 5:34 pm)wibblejunior wrote I love how I came into this thread just to see people fighting over where the NSA screen should be.Would be nice for a mix of both
On the other hand, if these are supposed to be entering service in September, then will they be recieving 72-reg plates or just 22-reg plates?
