24th March 2024 Changes
PB0003954/304
Variation GO NORTH EAST LIMITED 309 (309, 307) North Shields Newcastle
PB0003954/1389
Variation GO NORTH EAST LIMITED 354 (354) North Shields Newcastle
PB0003954/1388
Variation GO NORTH EAST LIMITED 353 (353) North Shields Cramlington
PB0003954/1221
Variation GO NORTH EAST LIMITED 1 (1) Whitley Bay Metrocentre
PB0003954/1194
Variation GO NORTH EAST LIMITED 687 (687) Newbrough Hexham
PB0003954/1198
Variation GO NORTH EAST LIMITED 684 (684) Hexham Newcastle
PB0003954/1350
Variation GO NORTH EAST LIMITED 891 St Thomas More Catholic Scool Wooside -
PB0003954/1261
Variation GO NORTH EAST LIMITED 876 Hamsterley Mill Thorp Academy
PB0003954/1377
Variation GO NORTH EAST LIMITED X39 (X39) Cobalt Park Newcastle
PB0003954/808
Variation GO NORTH EAST LIMITED X66 (X66) Metrocentre Gateshead Metro
PB0003954/1151
Variation GO NORTH EAST LIMITED 41 (41, 41A) Hadrian Park Wallsend
PB0003954/559
Variation GO NORTH EAST LIMITED 10 (10, 10A, 10B) Hexham / Prudhoe / Blackhall Mill Newcastle
PB0003954/1387
Variation GO NORTH EAST LIMITED 352 (352) Cramlington Newcastle
PB0003954/1390
Variation GO NORTH EAST LIMITED 355 (355) Forest Hall Newcastle
PB0003954/1156
Variation GO NORTH EAST LIMITED AD122 (AD122, AD12) Walltown Roman Army Museum Hexham
RE: 24th March 2024 Changes
(09 Feb 2024, 6:17 pm)Michael wrote PB0003954/304
PB0003954/1389
PB0003954/1388
PB0003954/1221
PB0003954/1194
PB0003954/1198
PB0003954/1350
PB0003954/1261
PB0003954/1377
PB0003954/808
PB0003954/1151
PB0003954/559
PB0003954/1387
PB0003954/1390
PB0003954/1156
I heard everything is getting merged into one large service like this:
Cramlington - Blyth - Whitley Bay - Cullercoats - Tynemouth - North Shields - Billy Mill International - Rake Lane Hospital - Cobalt - Silverlink- Percy Main - Howdon - Hadrian Park - Wallsend - Byker - Newcastle- Gateshead - Lobley Hill - Whickham - Metrocentre - Denton Burn - Throckley - Heddon - Wylam - Ovingham - Ovington - Corbridge - Hexham - Newbrough.
Every 20 mins.
X39 will have some extra journeys added.
Sent from my SM-A526B using Tapatalk
(09 Feb 2024, 6:26 pm)MurdnunoC wrote I heard everything is getting merged into one large service like this:
Every 20 mins.
X39 asides, it's not the first of April yet!
(09 Feb 2024, 6:32 pm)L469 YVK wrote X39 asides, it's not the first of April yet!
You should tell yourself that the next time you come up with a Coast Road suggestion or variation.
Besides, this service goes to Billy Mill International. The metropolis of Tyne and Wear.
Don't see any major changes looking at them, think most likely timetable changes.
Let's hope Hadrian Park haven't kicked off since the 2330 310 got changed to a 2345 309 otherwise it will be back to long walks if last bus is changed back to a 307!
Another thought......if more time is needed on the 309 due to NT Council's s*** traffic management plus a 20 minute frequency via High Farm being enough with deckers on the 307, would a re-route of daytime 309 services via Selby Gardens not be on the cards? Some early morning and all evening services could still run via High Farm to give a regular 30 minute service like now.
(11 Feb 2024, 6:25 pm)L469 YVK wrote Another thought......if more time is needed on the 309 due to NT Council's s*** traffic management plus a 20 minute frequency via High Farm being enough with deckers on the 307, would a re-route of daytime 309 services via Selby Gardens not be on the cards? Some early morning and all evening services could still run via High Farm to give a regular 30 minute service like now.
Probably wanted to make it every 10 minute along Mullen Road (for whatever reason) since Mullen Road now has the 41/41A/335/307/309 all going along it to Battle Hill
(11 Feb 2024, 6:33 pm)Aaron21 wrote Probably wanted to make it every 10 minute along Mullen Road (for whatever reason) since Mullen Road now has the 41/41A/335/307/309 all going along it to Battle Hill
I think a 20 minute service using deckers should be sufficient with the 307 alone. But the traffic situation is only going to get worse around Whitley Bay and Preston Grange.
(11 Feb 2024, 8:45 pm)V514DFT wrote Im surprised to see the 41 clinging on for dear life
Long as they withdrawn the 41A and reroute the 41 to go via Wiltshire Drive. The absolute hell that is going on is shocking the fact they can't even keep to timetable and the fact 99% of the time the 41 is being followed by a 41A or you have two 41A following each other.
Well working out the 308 & 309, the 309 dropping High Farm would save 2 minutes in each direction. So would create an 8/12 split between the 308 & 309 between NT Hospital & Blyth although still some even headway. Then for the time saved not serving High Farm, could then re-time the 308 & 309
308 / 309
Blyth: 09:51 / 10:03
Whitley Bay Cemetery: 10:07 / 10:19
Whiltley Bay Centre: 10:19 / 10:31 (+2 mins)
NT Hospital: 10:27 / 10:39 (+1 min)
New York Greenlea (309): 10:44 (+2 mins)
Billy Mill (308): 10:36 (+2 mins)
Newcastle: 11:03 / 11:18
308 would have 5 minutes layover in Blyth and 309 would have 7 minutes.
(11 Feb 2024, 10:51 pm)L469 YVK wrote Well working out the 308 & 309, the 309 dropping High Farm would save 2 minutes in each direction. So would create an 8/12 split between the 308 & 309 between NT Hospital & Blyth although still some even headway. Then for the time saved not serving High Farm, could then re-time the 308 & 309
308 / 309
Starting to get sick of these repetitive boring posts about the Coast Road services
Go north east and Arriva have entered into an enhanced partnership agreement. So are services likely to change significantly? No
(11 Feb 2024, 11:31 pm)Thomas12 wrote Starting to get sick of these repetitive boring posts about the Coast Road services
Well not significantly, but both GNE & Arriva are going to need to find the time from somewhere with the ever increasing congestion levels around Whitley Bay, Foxhunters and Preston Grange.
(12 Feb 2024, 2:11 pm)L469 YVK wrote Well not significantly, but both GNE & Arriva are going to need to find the time from somewhere with the ever increasing congestion levels around Whitley Bay, Foxhunters and Preston Grange.
Why should they? The continual slowing of bus services due to poorly planned developments increasing congestion should not be the responsibly of the bus operator to resolve, nor should it be the passenger penalised.
The local authorities need to provide major and significantly beneficial bus priority.
However, as we all know, promoting the bus over the car and throwing money that goes against the private motorist isn't a vote winner, so nobody will do it and we end up with slow public transport and frequency reductions to permit reinvestment of running time.
(12 Feb 2024, 8:37 pm)RobinHood wrote Why should they? The continual slowing of bus services due to poorly planned developments increasing congestion should not be the responsibly of the bus operator to resolve, nor should it be the passenger penalised.
You're so right, the ironic part of it all, is the congestion is being caused by cycle lanes being stuck in everywhere, in completely inappropiate places. I'm all for cycle lanes but not at the cost of public transport and it's not the first time either.
(12 Feb 2024, 8:41 pm)Storx wrote You're so right, the ironic part of it all, is the congestion is being caused by cycle lanes being stuck in everywhere, in completely inappropiate places. I'm all for cycle lanes but not at the cost of public transport and it's not the first time either.
308 far cry from the days when the driver could rock up to the awaiting Leyland / Volvo Olympian, Scania N113, Lowlander......then give it the beans with no traffic calming measures!
Rake Lane is a complete and utter mess! Agree with the comments about why should operators budge.
I'm sure GNE, Arriva and TNE will work something out. But think the only way to add time will be for GNE to drop High Farm on the 309 during the day and run back via Selby Gardens.
Any sunny Sundays usually spell chaos on the 308 & 309. At least passengers on the 307 no longer have to suffer unlike when the 310 used to regularly have to go light to Verne Road / North Shields after severe late running on the 309 on Bank Holidays or busy Sundays.
PB0003954/1389
PB0003954/1388
PB0003954/1221
PB0003954/1194
PB0003954/1198
PB0003954/1350
PB0003954/1261
PB0003954/1377
PB0003954/808
PB0003954/1151
PB0003954/559
PB0003954/1387
PB0003954/1390
PB0003954/1156
https://bustimes.org/licences/PB0003954
(12 Feb 2024, 11:19 pm)V514DFT wrote Is the 309 a mistake?, or has the 307 been canned
I think it just looks like that because the registration is combined. The 307 is still mentioned on the registration.
Will likely be a mistake or how the DVSA have entered the timetable.
(12 Feb 2024, 9:36 pm)DaveFromUpNorth wrote Where can you find the draft timetables?
They normally come out two weeks after an application has been submitted. Normally traveline have them first.
(15 Feb 2024, 12:42 pm)OrangeArrow49 wrote GCT have got the 335/351/359 and GNE have got the 342. Is that correct?
Could the 684 changes be a 2-hourly service on Sundays as was accidentally revealed in the 28th January service changes?
If gct get the 351/335/359 in March. Then I'd expect the 19/342 to be taken off them. How they will mange that with them still having the 19/342 will shock me
(15 Feb 2024, 1:52 pm)Aaron21 wrote If gct get the 351/335/359 in March. Then I'd expect the 19/342 to be taken off them. How they will mange that with them still having the 19/342 will shock me
According to VOSA, GNE still have those services but have timetable variations.
(15 Feb 2024, 2:23 pm)Michael wrote According to VOSA, GNE still have those services but have timetable variations.
Unless it's come in the last 24 hours, there's nothing on them either way. Think you've got confused with the 352-355.
(15 Feb 2024, 10:13 pm)DaveFromUpNorth wrote If GNE has won the 342 contract then they have won the 41A contract as it interworks andnis part of the contract according to FOI
If they have (although no evidence to support they have) then yes.
